BrettLP
Jan 09, 2018Initiate
Orbi Port forwarding (443) Not Working
Hi all, I'm at my witts end in trying to implement a simple port forward on the Orbi. Effectively, I have Home Assistant (HA) running in my network, and have installed a SSL Certificate and imple...
- Jan 09, 2018Some ISPs block port 443, inbound, to prevent people from hosting web servers.
The Orbi could be using port 443. Unfortunately, I don't think there's any easy way to tell short of disabling any features that could be using it, such as remote management, UPnP, etc.
Can you use a different port, like 22 (SSH), instead of 443?
TheEther
Jan 09, 2018Guru
fitsnugly
Jan 09, 2018Star
Port forwarding 443 works for me and my apache web server. So it's not the Orbi, sorry :-(
