iamallright's avatar
iamallright
Follower
Jun 15, 2020
Orbi RB40 keeps blocking certain devices
RB40 with two satellites (RB20) seems to have a hard time staying connected to specific devices, even with the satellite next to the device.  The system "Blocks" acess often and when I try and change in Access Controls, it wont switch to Allow.
Been getting worse and worse since early 2020
1 Reply
  • FURRYe38's avatar
