Anonymous
Jan 29, 2022Orbi RB50R firmware file incorrect
I am trying to upload my orbi firmware manually since it does not let me update automatically on my orbi settings.
Whenever I upload the RBR50 file image, it says "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
After downloading the *.zip file for the router from the Orbi downloads page, did you 'extract' the *.img file from the *.zip file?
Netgear uses different file types for different products. For the RBR50 router, the correct fiile will have a file extension of "img".
- Anonymous
www.imgur.com/UA33ATt.png
Yeah this is the file I used.
Also, the satellite was already updated to this version.- CrimpOnGuru - Experienced User
This appears to be correct. All I can suggest is downloading and unzipping another copy.
