DJ5421
Jul 07, 2018Aspirant
Orbi RB53 setup
I bought the Orbi Router + 2 satellite system. I have a DSL modem that I have connected to the Orbi router and one of the satellites. Question: for the satellite that I connected directly to the DS...
Jul 07, 2018Guru - Experienced User
You need to connect all satellites to the Orbi router, not the ISP modem.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
