angusmadmac
Dec 05, 2018Aspirant
Orbi RBK 50 AC3000
Bought yesterday set up easy . everything working
not working today
i have reset plusnet hub one fttc
the orbi is plugged into port 1
i get a 10.0.0. ip
ping 8.8.8.8
but will not allow ...
ekhalil
Dec 05, 2018Master
Looks to me that the plusnet hub is a router providing DHCP functionality, right?. Is Orbi set in AP mode?
angusmadmac
Dec 06, 2018Aspirant
Sorry bit of a noob , i had plugged in rbk50 into plusnet hub one (yellow port on rbk50). and with the android app i got it working and then switched on satillite and got that blue . everything was working after intial switch on . checked firmware up to date . switched off plus net hub wifi. came home yesterday and i was able to connect to ssid , ping google dns ok but cannot access internet . reset everything (off and on)had to set up orbi again switched on wfi on hub . I needed this to extend wifi coverage in my house and also getps4 and xbox one (not at the same time)connected to internet. i had a fall back of the develo powerline adapter so son was happy .
