angusmadmac
Dec 05, 2018Aspirant
Orbi RBK 50 AC3000
Bought yesterday set up easy . everything working
not working today
i have reset plusnet hub one fttc
the orbi is plugged into port 1
i get a 10.0.0. ip
ping 8.8.8.8
but will not allow ...
Dec 06, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
not working today
i get a 10.0.0. ip
ping 8.8.8.8
but will not allow me out to internet on laptop or ps4 or xbox
