Aquaman01
Oct 02, 2018Aspirant
Orbi RBK-50 and Viasat RG110N-030 Satellite Internet Modem
 Im in a Rural Area where the only option for Internet is a Satellite service like Excede.
 I have the Viasat RG1100N-30 Modem/WIFI router working, but when plugging in the ORBI (Yellow Port), it Cor...
randomousity
Oct 02, 2018Luminary
I have the Viasat RG1100N-30 Modem/WIFI router working, but when plugging in the ORBI (Yellow Port), it Corrupts the LAN-IP Settings and that Modem has to be factory reset to get access to it again. Also tried a Crossover Cable and Orbi says it does not have internet but you have limited internet. With my Cell you can access internet but not use WIFI calling. Thru the Viasat Modem, I do have WIFI calling, just not thru Orbi. After 15 minutes or so, the LAN-IP setting go corrupt and Factory reset is needed to get access to the Viasat Modem again. Any help in getting Orbi working on the Viasat RG110N-030 Modem would be appreciated.
Is your Excede modem routing as well? I know you said it's a modem/router, but is the routing function enabled? Ideally, you only want one router performing NAT and DHCP on your network, and they definitely need to be on different (sub)nets.
So, either:
1. the modem should also act as the router, handling routing, NAT, DHCP, and the Orbi should only be in access point mode, just handling your wifi (with wifi turned off on your modem, if you can),
or
2. you should have the modem act only as a modem, by putting it in bridge mode, disabling router functionality, so no NAT, no DHCP, no wifi, etc. And then your Orbi can act as the router and wifi access point.
I don't know that one of those is preferable to the other, so unless you have a strong reason to prefer one over the other (e.g., you really want to use some feature the Orbi has that the modem lacks, which would obviously require you to use the second scenario) you might just go by whichever is easier for you to implement.
You could probably make it work with both the modem and Orbi performing routing functions if you make sure they're both managing different networks, or, at least, subnets. But suffice it to say that it's worse than either of the above options, and if you don't know what I'm talking about it's going to be more complicated than you probably want to deal with. Even if you do know networking and subnetting, it's still probably not worth doing, but I guess have at it.
Aquaman01
Oct 03, 2018Aspirant
Randomousity,
I have disabled (Put in Bridge Mode) the WIFI on the Excede Modem/ Router knowning you should only have one WIFI going at a time. I will have to experiment more with this setup this weekend. The equipment is at my remote property three hours away from me.
Thank You for the advise.
