springy
Jun 03, 2020Initiate
Orbi RBK20 with Sky Plus HD
Have just set up Orbi RBK20 via my PlusNet hub and Sky+ box is connected to Orbi via wireless however On Demand is now not available and recordings are failing.
Has anyone had this issue and successfully resolved it?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
springy wrote:Have just set up Orbi RBK20 via my PlusNet hub and Sky+ box is connected to Orbi via wireless however On Demand is now not available and recordings are failing.
Do you have it setup like this?
plusnet hub------>orbi router------->sky+ box?Is the plusnet hub in passthrough/modem only mode?
or the orbi in access point mode?
You could be in a double nat and the sky+ box not on the same subnet as the plusnet hub which could cause it to not record/view. https://kb.netgear.com/30186/What-is-Double-NAT
- springyInitiate
Thanks all for the advice - it is connected plusnet hub--->orni router/satellite--->sky+ box
Having managed to get into the Orbi set up, I have switched it from router mode to AP mode and this seems to have resolved the issue
Good to hear. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Couple of options,
