TXCISCO11
May 05, 2018Aspirant
Orbi RBK22 setup trouble
In the process of setting up our new Orbi RBK22. We have AT&T Uverse, which uses a router/modem combo. So was planning to connect the Orbi via a switch off the router/modem and setup as an access p...
TXCISCO11
Just one follow up, if on the screen to begin Router setup I select dismiss, it does open the app and shows the Orbi system online and has great connection. Did a speed test and was as expected up/down. But still not able to access internet on devices connected to the Orbi. Also, did not see where Advanced Settings were or where to set up system as access point (AP).
