TXCISCO11
May 05, 2018Aspirant
Orbi RBK22 setup trouble
In the process of setting up our new Orbi RBK22. We have AT&T Uverse, which uses a router/modem combo. So was planning to connect the Orbi via a switch off the router/modem and setup as an access p...
May 06, 2018Guru - Experienced User
I recommend that you contact your ISP and ask them about helping you disable the Modems radios and or bridge it. I don't think Uverse suppors bridging so you need to have them help you fully disable the wifi radios. Disable any Firewall and uPnP as well on the modem.
Then you'll need to use the modems DMZ for the IP address the Orbi router gets from the ATT modem. Input this IP address into the DMZ, then reboot the modem and Orbi. Should have internet here.
