Oronzo
Dec 15, 2018Tutor
ORBI RBK23: non riesco ad utilizzare ps4
ho appena installato ORBI RBK 23 in casa mia e non riesco ne ad utilizzare la ps4 ne scaricare e aggiornare le app da app store.
come posso risolvere questo spiacevole problema?
ekhalil
Dec 17, 2018Master
Oronzo wrote:
ekhalil thanks a lot man for the help.
it seems that everything is working properly right now.
the only thing that i am not able to do is to pause/start connection to a specific device. do i have to do something to enable this function?is it also possible to prioritize the connection to a specific device or ORBI does it independently?
thanks again!!
I'm glad that things are working now!
To be able to pause/start connections to certian devices you need to activate "Access Control". Please use the web GUI as follows to activate the functionality:
Currently it's not possible to prioritize connectivity of certain devices over others. I think -and really hope- that QoS features will be added soon or later to Orbi. I'm also looking forward for that!
Oronzo
Dec 29, 2018Tutor
i am really sorry to bother you again but i am facing another problem with my device.
a week ago i had a problem with my provider which has been fix only today.
after having fix the problem with the modem i have turned on the orbi system.
unfortunately neither the router nor the satellites were working.
due to that, i have resetted the router through the button (not sure about this).
now the situation is the following:
- only the router is working (it is connected with wired connection to the modem)
- both the satellites are not found (even if they are in the same position then before)
- orbi has created two different wifi lan (now i have the wifi of the modem and 2 orbi wifi)
can you please help me in fix this big trouble??
- ekhalilDec 29, 2018Master
Do you still see the Satellites in the Attched Devices menu in the GUI under >> BASIC >> Attached Devices?
You should see them as "Disconnected" and you should also see "Remove" beside that, right?
