Oronzo
Dec 15, 2018Tutor
ORBI RBK23: non riesco ad utilizzare ps4
ho appena installato ORBI RBK 23 in casa mia e non riesco ne ad utilizzare la ps4 ne scaricare e aggiornare le app da app store.
come posso risolvere questo spiacevole problema?
Oronzo
Dec 29, 2018Tutor
i am really sorry to bother you again but i am facing another problem with my device.
a week ago i had a problem with my provider which has been fix only today.
after having fix the problem with the modem i have turned on the orbi system.
unfortunately neither the router nor the satellites were working.
due to that, i have resetted the router through the button (not sure about this).
now the situation is the following:
- only the router is working (it is connected with wired connection to the modem)
- both the satellites are not found (even if they are in the same position then before)
- orbi has created two different wifi lan (now i have the wifi of the modem and 2 orbi wifi)
can you please help me in fix this big trouble??
ekhalil
Dec 29, 2018Master
Do you still see the Satellites in the Attched Devices menu in the GUI under >> BASIC >> Attached Devices?
You should see them as "Disconnected" and you should also see "Remove" beside that, right?
