Daddykev
Aug 21, 2020Aspirant
Orbi RBK23 router going offline
Hi there, I've had my netgear orbi rbk23 for roughly 24 hours and I've had the router go offline 3 times. When I go to the orbi app it shows the router offline and both satellites show online.
I have the system set up in router mode, and I bridged my ISPs modem/router so the orbi SSID is the only one available.
It's extremely annoying if the router is randomly going to offline several times per day, please help!
- MstrbigMaster
Need more information?
Who is your ISP?
What ISP device is your Orbi router connected to?
Did you reboot your ISP modem/router, before starting the Orbi router install?
Have you changed the network cable connected from the ISP device to your Orbi router?- DaddykevAspirantThanks for the reply.
Who is your ISP? Rogers (canadian)
What ISP device is your Orbi router connected to? Hitron CODA 4582
Did you reboot your ISP modem/router, before starting the Orbi router install? Yes
Have you changed the network cable connected from the ISP device to your Orbi router? No- MstrbigMaster
Very nice router. You said you disabled the router's DHCP and WIFI settings?
I assume you connected the Orbi to the ISP modem/routers LAN port?
Anything between the ISP router and the Orbi, other than the network cable?
Do you lose internet when you see the router offline?
