Nige147
Nov 07, 2019Aspirant
Orbi RBK23
Hi I’ve just bought a orbi RBK23 system
I was just wondering when I set it up if I connect to my existing router from my Internet provider or do I unplug it and just connect the orbi
- Retired_Member
I was just wondering when I set it up if I connect to my existing router from my Internet provider or do I unplug it and just connect the orbiThe RBK23 is a router, therefore you don't 'need' another router. You can run 2 routers, but it requires special config and IMHO is not recommended.
You will need a modem
- Nige147AspirantThanks
Looking forward to setting it up this weekend
I just hope it is as good as they say it is and improves my WiFi range
