googlewave123
Jun 22, 2018Aspirant
Orbi RBK30 - Replacement RBW30 - Not Connecting
Frustrated customer here, writing this as I've already spent a total of 6+ hrs on the phone with Netgear support.
I have the RBK30 which is a combo Orbi router and wall plug satellite.
Ulairi
Jun 22, 2018Luminary
I'm also struggling with a RBW30. It connects to the RBR50 router okay, but only via 2.4GHz backhaul, and it causes diconnects on one of four iPhones in the house when roaming into it's broadcast zone. Full background in these threads : link 1 link 2
I had all sorts of problems with it initially and then with the replacement via RMA. The original and the replacement seemed to settle down and behave better after a factory reset and being switched on and off a few times. The factory resets were part of resetting all my Orbi devices (for a separate speed throttling issue), and the power cycling was because it was causing disconnects and my son had to keep switching it off.
I'd try a Factory Reset (just the RBW30, but maybe the whole system if you haven't configured it too much) and see what happens.
Please let us know what happpens - I'm desperate to work out what's going on with my RBW30.
- googlewave123Jun 25, 2018AspirantI tried a factory reset and didn’t work. The satellite goes to magenta after I push the sync button on both devices.
Netgear is going to send me a replacement router. Who knows if that will work...
Overall time spent is now 7+ hrs, kind of ridiculous...
