diodorus
Nov 07, 2017Guide
Orbi RBK30 + Virgin Superhub 2
Hello! I currently have a Virgin media superhub 2, and I am thinking of buying a Orbi RBK30. I understand that one option would be to put the Superhub in modem-only mode, and put the Orbi in ...
- Nov 08, 2017
All of the above. In this configuration, your Virgin box is the DHCP server which allocates IP addresses to all of the devices on the network, regardless of whether they are wired to the router or the Orbi, or wirelessly to the Orbi.
NickC4555
Nov 08, 2017Star
Yes you will, I have the same setup, but with a Virgin Hub 3. The connected devices list on the Orbi control panel won't show the ones connected to the router, you'll have to use the Virgin admin screen for that.
diodorus
Nov 11, 2017Guide
"The connected devices list on the Orbi control panel won't show the ones connected to the router, you'll have to use the Virgin admin screen for that."
FYI, I bought it, and on the Orbi control panel I actually also see the devices connected to the Virgin router.
