JHanno
Sep 18, 2017Aspirant
Orbi RBK40-AC2200 Speed Drop
Hi Everybody,
I posted here yesterday about a problem I had when I upgraded to the AC3000 unit.
https://community.netgear.com/t5/forums/replypage/board-id/Orbi/message-id/13758
I have since gone and re-exhanged that for a set of the AC2200 but the speed is still down from ~100 mbps to 30mbps.
I am using the Orbi system in conjunction with a Xfinity Triple play modem/gateway. When connected directly to the modem's wifi I get 100+ Mbps but when running a test through the orbi wifi it is 30mbps. This was not the previous case before I swapped and re-swapped systems.
Please let me know if there are any ideas as to why this happened.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Jhanno
What firmware version are you on? have you tried the 2.0 firmware ?
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
DarrenM
