Klysner's avatar
Klysner
Orbi RBK40 as AP
Hi.
I have a RBK40 with a RBW30. But it's not enough for my house. I would like to buy a RBK20 with RBS20, because of the price, instead of buying two satellites. Then use the RBK20 as router, RBS20 and RBW30 as satellites for the RBK20. Then the RBK40 as a wired AP to the RBK20.
Is this possible?
If so, do I need two diffent SSID's?
BR, Kim.
  • Klysner wrote:
    Hi.
    Is this possible?
    BR, Kim.
    I think that you meant RBR in all RBK that you mentioned above! :)
    Yes, the configuration you are suggesting above should be ok:
    RBR20 as your main router (in Router Mode) with two satellites: RBS20 and RBW30.
    Then you want to use the RBR40 as a wired AP (in AP Mode). In this case, yes you have to use 2 different SSID's in the RBR20 and RBR40.
    • Klysner's avatar
      Klysner
      Yes I saw this just now. Hoping for a firmware update, so the RBK40 can work as a satellite. Don't wan't two SSID's again. That's why I changed to the Orbi system.
      • FURRYe38's avatar
        Any RBR## unit will never be supported as a satellite. Only works in main router mode or AP mode only. Will not work as a satellite or work as a extender for wifi.
