htngwilliam
Jul 06, 2018Aspirant
Orbi RBK40 keep disconnecting!!!
I am on m1 1gbps network and I have a pair of RBK40. The installation went very well. I plug the modem directly into the RBK40 router. The setup went well and internet is great. However, I keep hav...
htngwilliam
Thanks. Initially the 2.4gHz channel is set to auto and I change it to 1. Also did a reset and it seems ok. The speed and range is awesome as long as it don’t gets disconnected. Keep my finger cross
Jul 07, 2018Guru - Experienced User
Sounds good. Enjoy.
