SaugertiesWiFi
Mar 17, 2019Follower
Orbi RBK44 and Spectrum cable modem
Just got my Orbi RBK44 system yesterday. I've tried several times with different ethernet cables to get my Orbi to get an internet connection from the Spectrum modem. No luck. The Orbi and the 3 sate...
Chuck_M
Mar 17, 2019Mentor
Need some information first....
What is the make/model of the modem or router you are trying to plug into Orbi?
What mode are you running Orbi in (router or AP?)
Are you plugging your modem into the yellow WAN port?
If your modem is JUST a modem (and not a router), you very well may want to reboot everything starting with the modem first, then Orbi, then your PC.
