OrbiUser2020
Feb 23, 2020Aspirant
Orbi RBK50 – IP Address Change from 10.0.0.1 to Verizon 192.168.1.1
Good Evening I just purchased "NETGEAR Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50)" I connected it and it works good, the only issue is that the unit created it own LAN Ne...
Feb 24, 2020Guru - Experienced User
That won't work in that configuration. Having 2 routers on the same line using the same IP address or with in the same IP address pool is not standard networking practice nor is it supported.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Since you seem to be using the ISP modem for your main host router, I recommend using option #3 with the RBR50.
OrbiUser2020 wrote:Good Evening
I connected it and it works good, the only issue is that the unit created it own LAN Network (10.0.0.1 - 10.0.0.2 to 10.0.0.254)
I am using Verizon Fios 1gb Router/Modem(Model Name: Fios-G1100) and my LAN Network is 192.168.1.1, all of my devices are on this network and by connecting devices to Orbi puts them on the new Orbi LAN network and they can not be seen by my main LAN Network.
I need all of my devices to be teh same LAN Network.
I've tried to change the Orbi IP to 192.168.1.30 and reserve DHCP range 192.168.1.31 to 192.168.149 for Orbi, but I keep getting the folowing message - "The IP address conflicts with the WAN IP subnet. Please enter a different IP address". I have played artound with it and read Community posts, but still was not successfull.
I have endup called Netgear Support, but their Tech Support people are cluless and they treat you like an idiot.
I've wasted 2 hours on the phone with them, they tried to connect me to higher level support but disconected me 3 times and I gave up on them.
I am sure that I am not the only one who has teh same problem,
Can anyone walk me step by step on how to do it?
Thank you In Advance.
Gary
OrbiUser2020
Feb 25, 2020Aspirant
Thank you
I already set it up as AP, but not happy with performance.
WiFi speed is jumping all the time. it varies from 56 mbps to 865 mbps
It is very strange. My Verizon WiFi are more or less stady at about 120mbps to 180mbps
Thank you
- FURRYe38Feb 25, 2020Guru - Experienced User
Did you turn OFF The wifi radios on the verizon router? These need to be disabled.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
