OrbiUser2020
Feb 23, 2020Aspirant
Orbi RBK50 – IP Address Change from 10.0.0.1 to Verizon 192.168.1.1
Good Evening I just purchased "NETGEAR Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50)" I connected it and it works good, the only issue is that the unit created it own LAN Ne...
OrbiUser2020
Feb 25, 2020Aspirant
Thank you
I already set it up as AP, but not happy with performance.
WiFi speed is jumping all the time. it varies from 56 mbps to 865 mbps
It is very strange. My Verizon WiFi are more or less stady at about 120mbps to 180mbps
Thank you
Feb 25, 2020Guru - Experienced User
Did you turn OFF The wifi radios on the verizon router? These need to be disabled.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
