slavrenz's avatar
slavrenz
Orbi RBK50 - issues with Skype and other remote video services
Is anyone else having issues with Skype, Teams, Zoom, etc. running very poorly with the Orbi Mesh Routers? With the stay-at-home measures over the last month, I've noticed frequent issues with poor bandwidth, pixelation, garbled voices, etc.
I realize there are about 1,000 different troubleshooting issues, and I won't detail everything I've done. But suffice it to say, I don't have speed issues with any other apps, I have a 100 Mbps+ connection to Comcast, and the quality of my line (jitter, SNR, etc.) is fine. I've also tried the Port Triggering options for these services to no avail.
I'm happy to entertain suggestions for troubleshooting, but mostly I'm looking to see if issues with Skype, etc. are a known issue with the current firmware (2.5.1.8). I've tried downgrading to an earlier firmware and re-upgrading, and that hasn't really fixed anything.
  • Retired_Member's avatar
    Retired_Member
    I don't think it's unique to any particular piece of software.  Numerous complaints about (2.5.1.8).
    Revert back to the one that was most stable for you....or.....standby for dozens of useless questions that will only waste your time.
    • slavrenz's avatar
      slavrenz
      Yeah, that's what I was thinking...I've tried all the troubleshooting stuff. Sounds like I need to wait for a new firmware update
      • FURRYe38's avatar
        Did you downgrade FW?
        Be sure Circle or Armor isn't enabled. Circle has been causing problems lately.
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Are the problems see over wired and wireless connections?
    Please try a factory reset and setup from scratch with the RBR and RBS.
