Marky-P
Jan 27, 2020Tutor
Orbi RBK50 - WIFI drop outs constantly
Ever since replacing my Asus RTAC87U with the RBR50 I have been having constant Wifi drop outs on all devices. I have observed on some devices including my S10+ and a Samsung Galaxy Tablet showing th...
Jan 27, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration? If this is a managed switch, try the RBS directly connected to the RBR, by passing this switch. IGMP should be disabled on managed switches and use of "Green Ethernet" featured switches is not recommended.
Beamforming and MIMO(MIMO may or maynot be needed) and WMM should always be enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Marky-PJan 28, 2020Tutor
Have tried all options as mentioned. Similar issue to https://community.netgear.com/t5/Orbi/Orbi-RBR50v2-WiFi-Connection-Drops-on-Smartphone/m-p/1854753#M81285
Have tried everything. Considering moving back to ASUS- FURRYe38Jan 29, 2020Guru - Experienced User
Would be nice if you gave feed back next time to the questions presented so we get more of a picture of what you have goign on there. Possible you just have a faulty unit. Not everyone has this problem. Contact NG support and ask about an RMA.
Good Luck.- JimboNZMar 30, 2020AspirantExactly the same issues. Been trying everything - different switch configs, MIMO, beam forming, DHCP etc. You name it... Clearly an underlying issue with these units. These posts have been going for ever. What's Netgear going to do about it????
- my_coronJun 19, 2020Tutor
Hi,
I wanted to add to this thread. I purchased the RBK50 with the acompanying sattlite and my setup is (In Australia) a Fibre 100M/20M service which connects to my carrier NTU and then my RBK50 Router. I have setup with approximately 10+ devices to my wireless network and when it is not dropping out, its been a life changer. But like many I am experiencing intermittent wireless drop outs. My setup is in a single level home with approximately 160 sqmetre living area and I have the sattelit at approx the same recommended distance. It has been 5 days and with the intermittent drop outs have been inconvenient. Steps taken:
Firstly I am running the fimware V 2.5.1.16 which is the latest available for Australia
1. factory reset
2. unplugged all cables and reconnected
3. contacted netgear support and they advised to change the wireless 5GHz from 36 to 40 and then to keep changing this settings until the drop outs resolved. Its current aat 48 and after calling back to neatgear support they have emailed the case to suggest that the RBK50 units is faulty and recommended I have it replaced. Iam convinced that there was more that could be troubleshooted, and will exercise that if all my options get exhausted.
But I wanted to share that I have performed the follow as you have suggested of
1. change 2.4ghz channel from auto to 1
2. disabled 20/40Mhz co-existence
3. enabled BEAMFORMING
I've applied and have rebooted. Are there any other suggestions should this not work?
I will update on status - Im crossing my fingers that this will work
- FURRYe38Jun 20, 2020Guru - Experienced User
my_coron wrote:Hi,
1. factory reset
- my_coronJun 20, 2020Tutor
Ok so an update from yesterday. Firstly to answer the distance from Route to Sattelite. It is approximately 55 feet. The sattelite light is blue blue on reboots. Secondly I have approximately 7 other networks.
Ok the bad news first. After making those changes described in my first post whilst the wireless connection was on for much longer (approximately 5 hours) it eventually dropped.
So change follow changes were made on the Orbi in firmware:
2.4GHz Channel - 01 and then to 06 after another drop out
5GHz Channel: left on 48
Both 2.4GHz and 5GHz preamble modes to both Short Preamble config
Disabled Dasiy Chain Mode
So my current settings before I went to bed are now as all checked-boxed recommended by Furrye38 and include settings of:
SSID Wireless
2.4GHz: 11
5GHz: 40
One thing to note - Armor is still activate as I have for the BitDefender subscription (after some challenges in getting the licenses activated, nonetheless I wanted to commend also the BitDefender service desk in Romania who were patient and supportive to assist)
I will monitor and update all.
