Marky-P
Jan 27, 2020Tutor
Orbi RBK50 - WIFI drop outs constantly
Ever since replacing my Asus RTAC87U with the RBR50 I have been having constant Wifi drop outs on all devices. I have observed on some devices including my S10+ and a Samsung Galaxy Tablet showing th...
Marky-P
Jan 28, 2020Tutor
Have tried all options as mentioned. Similar issue to https://community.netgear.com/t5/Orbi/Orbi-RBR50v2-WiFi-Connection-Drops-on-Smartphone/m-p/1854753#M81285
Have tried everything. Considering moving back to ASUS
Jan 29, 2020Guru - Experienced User
Would be nice if you gave feed back next time to the questions presented so we get more of a picture of what you have goign on there. Possible you just have a faulty unit. Not everyone has this problem. Contact NG support and ask about an RMA.
Good Luck.
- JimboNZMar 30, 2020AspirantExactly the same issues. Been trying everything - different switch configs, MIMO, beam forming, DHCP etc. You name it... Clearly an underlying issue with these units. These posts have been going for ever. What's Netgear going to do about it????
- FURRYe38Mar 30, 2020Guru - Experienced User
If your having similar problems and have tried everything, you'll need to make contact with NG support to continue the support effort. Not everyone has problems with there wifi. Some have had problem units being faulty in which NG has sent them new units. Something to ask NG support about:
https://www.netgear.com/support/#
Can try Voxels FW as well:
Good Luck.
JimboNZ wrote:
Exactly the same issues. Been trying everything - different switch configs, MIMO, beam forming, DHCP etc. You name it... Clearly an underlying issue with these units. These posts have been going for ever. What's Netgear going to do about it????- Retired_MemberMar 30, 2020
What's the score on this update?
