zannydu
Jan 29, 2019Follower
Orbi RBK50 & Circle - controlling an ethernet-connected PC?
Our Netgear Genie program on my laptop is super buggy (requires multiple logins, often does not show the Access Control checkbox, requires refreshing and restarting the softwear and/or the machines and devices in order to block and unblock), and the app isn'tmuch better, so I decided to try using the Circle app. We have an Orbi RBK50 system, and the primary "device" that I want to control is a PC that is connected to the router via an ethernet connection. Because gaming. It does not seem to be showing up in the list of devices on Circle. I am looking for confirmation that we should be able to control wired and wireless devices with Circle, and if so, how am I going to find it?
1 Reply
- ekhalilMaster
You should be able to control both wired and wireless devices with Circle.
To find the devices go to the Main Menu from the home screen on the app as follows:
Then select "Devices":
You should see all devices that were ever attached to Orbi (even if they are not currently connected). Look for the device with the MAC address as the name can be different than what you named it in Orbi.
