Rustyy's avatar
Rustyy
Tutor
Feb 26, 2019
ORBI RBK50 & RBS40 Drops wireless and wired connection
Hi team
I’ve been running the RBK50 with the one satellite for quite some time. I play a lot of games online and using the wireless connection to the PC - I was having spikes. I moved the satellite near the PC and connected his used a network cable. Perfect!
Seeing as I had moved the satellite closer it slightly impacted the other part of the house so I decided to invest in the RBS40. Setting it up. No issues. About 3 hours later and since then continuous dropouts. I’ve changed no settings whatsoever. I u plugged it the RBS40 this morning and the issues stopped it seems.
What could be causing this? I saw a post about rolling back firmware but this seems counter productive. I saw there is a new firmware out today? Should I update when I get home?
To say I’m frustrated is an understatement. When I first got the RBK50 I had massive issues changing between 2.4 and 5 and someone on here had instructions on how to split the frequencies. Was amazing since then. Could this have had some impact? Either way - it shouldn’t be this hard for something so expensive.
Hopefully you guys can point me in the right direction because if I can’t get it to work I’m returning everything and will get something else. I’ve have the RBK50 set up for 9 months and added the RBS40, yesterday afternoon.
Thanks in advance!
  • Rustyy
    What version of firmware are you running on your RBS50 and RBR50?
    Are you in a daisy chain setup or a hub and spoke setup?
    What setting do you have for Daisy chain in your web gui?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Rustyy wrote:
    Hi team
    Thanks in advance!
    • Rustyy's avatar
      Rustyy
      Tutor
      Update - The RBS40 was running some really old firmware. After trying and trying to update it to the latest we found the topic where it was advised to update something in between the newest and the older version. After being able to do that - it was finally recognising that there was a firmware update that was newer. Trying to then update through orbilogin.com. it froze up. Nothing happened. Then tried to add it manually. Now.... it continually cycles through, disconnecting, cycling through the white, going back to solid blue and then dropping out again. Not staying connected long enough to try and update the firmware further. What gives? As I said in my first post, this just seems way too hard. How can a new set of firmware not update? Why would you have to install a midrange version and then after all of that, it not even work!
      Any ideas? I am so close to just taking it back within the 7 day return policy. While that is happening - my connection is NOT dropping out using the RBK50 and the satellite, so at least part of the issue was resolved it seems.
