neukenuk
Jul 20, 2018Aspirant
Orbi RBK50 AC3000 and Sony KD-55X9005C Disconnects
Hi. I bought the RBK50 which arrived yesterday to replace R6120 which i had been having problems with with devices dropping on and requiring restart starting monthly then becoming weekly for absolute...
Jul 20, 2018Guru - Experienced User
What FW version is the Orbi system using?
Try diabling Daisy Chain, MIMO and Fast Roaming.
What is the distances between the router and Satellites? Feet? 30 feet to begin with is recommended...
- neukenukJul 20, 2018Aspirant
Firmware running at 2.1.4.16 which is the latest.
Those 3 settings were not enabled and remained disabled.
The route and satellite are vertically above each over between floors
I can’t hardwire the TV to router as TV is flush against the wall and the Ether port is on the back of the TV.
