neukenuk
Jul 20, 2018Aspirant
Orbi RBK50 AC3000 and Sony KD-55X9005C Disconnects
Hi. I bought the RBK50 which arrived yesterday to replace R6120 which i had been having problems with with devices dropping on and requiring restart starting monthly then becoming weekly for absolute...
Jul 20, 2018Guru - Experienced User
What is the distances between the router and Satellites? Feet? 30 feet to begin with is recommended...
What is the relation placement of the TV to the satellite and router? possible that placement of the satellite is not good for the TV. Can you power OFF the satellite and test the TV with the router only?
- neukenukJul 21, 2018Aspirant
Hi.
The router and satellite are about 15-20 feet apart from Lounge to Office through ceiling.
The satellite is about 4 ft away from the TV.
I tested switching off off the Satellite and the TV connected to the router with no issues. I tested Archos and the TV remained connected and functioned as it should do. So it does look like an issue with the satellite.
