neukenuk
Jul 20, 2018Aspirant
Orbi RBK50 AC3000 and Sony KD-55X9005C Disconnects
Hi. I bought the RBK50 which arrived yesterday to replace R6120 which i had been having problems with with devices dropping on and requiring restart starting monthly then becoming weekly for absolute...
Jul 21, 2018Guru - Experienced User
Try the satellite closer to the TV next to see if the TV will connect to it. After you get the satellite set up, besure to power OFF the TV then back on, it should connect to the satellite. You can check this by logging into the satellites IP address and looking at it's connected cllients list...
neukenuk
Jul 21, 2018Aspirant
The satellite has been back on for 8 hours and the TV is still connected to the Router. It will eventually bounce got the Satellite.
- FURRYe38Jul 21, 2018Guru - Experienced User
Have you power cycled the TV to see if it will connect to the satellite? The satallite maybe too close fo the TV. Seems like the TV likes the router signal over the satellite...
