ChrisRivers222
Jul 19, 2019Aspirant
Orbi RBK50 (AC3000) connection to vodafone router
Hi I have an Orbi RBK50 (AC3000) bought in 2018. It has been working happily with my plusnet router since then. However, I have now changed to vodaphone and have had problems connecting the new vodaf...
ChrisRivers222
Jul 24, 2019Aspirant
Vodafone Router HUAWEI 963168_HUAWEIVOX25
Firmware: 5.4.8.1.291.1.30.1.32.1.2
Model HHG2500
Thanks very much for your response. I have contacted vodafone, who advise that they router cant be used in bridge mode. So, I have follwed your guidance and have put the orbi in AP mode. To change double NAT, I now need to change the settings on the vodafone router. I attach screenshots of the wifi settings, and get a warning to turn these off - please can I check which settings I should use with the orbi in AP mode?
thanks for your support, which is much appreciated.
