ChrisRivers222
Jul 19, 2019Aspirant
Orbi RBK50 (AC3000) connection to vodafone router
Hi I have an Orbi RBK50 (AC3000) bought in 2018. It has been working happily with my plusnet router since then. However, I have now changed to vodaphone and have had problems connecting the new vodaf...
Jul 24, 2019Guru - Experienced User
I would switch off the WiFi network and WiFi enable buttons is all. This should fully disable the radios on the modem. Contact your ISP for further help with the modem.
Glad you go the Orbi setup for AP mode. :smileywink:
