fletcher6490's avatar
fletcher6490
Orbi RBk50 and Negear EX8000
Hello,
I'm trying to decide what my best course of action would be for incorporating the EX8000 to an Orbi router and satelite. I have a set of Zyxel AV2000 powerline adapters and I'm wondering if I should use a powerline adapter to connect the EX8000 via ethernet and put it into AP mode. Would this be beneficial or should I keep the EX8000 as an extender?
  • Retired_Member's avatar
    Retired_Member
    fletcher6490 wrote:
    Hello,
    The RBK50 covers large homes up to 5,000 sq. ft   Unless you're trying to provide wifi to the moon, I'd ditch the EX8000.  It'll only cause you problems.
    • fletcher6490's avatar
      fletcher6490
      I'm the type that likes things to be optimal and I'm also the type that hates to store relatively expensive equipment in the closet. Ultimately I would like to incorporate this into my network, as long as it isn't detrimental.
        Retired_Member
        Well there ya go...you have your answer.
  • FURRYe38's avatar
    I can confirm that my EX7700 doesn't connect to a RBR50 either. I presume that the Orbi and EX models may not be compatible.
    Blanca_O
    fletcher6490 wrote:
    Hello,
