Villy
Jun 25, 2018Aspirant
Orbi RBK50 bridged to FIOS Quantum cannot see my NAS wired LAN
Just set up today the RBR50 router and RBS50 satellite, the router is connected via cable to FIOS Quantum router, followed the instruction by disabling FIOS' wifi, and all works great. Well, the wifi...
- Jun 25, 2018
Where is the NAS connected? To the FIOS router or the Orbi?
NAS and all other devices should be connected to the Orbi router.
Is the Orbi running in router or AP mode?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Jun 25, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
