Len6's avatar
Len6
Orbi RBK50 changing password for Security Options (WPA2-PSK) resort back to old password
I have a Orbi RBK50 changing password for Security Options (WPA2-PSK) resort back to old password.  The router has firmware version V2.7.4.24.  I have reset the router with the 3 methods suggested and the last time kept the new password for 4 days and now after a reboot it's back to the old password.  I show correctly on the home page, but if you look at wireless password in basic and advanced it shows the old password.  How do I flush this out, so it reads correctly and holds the correct password.  By the way the password that keeps coming up is the old admin password and was never used for the Wi-Fi.
And what is the normal expected swing of speeds for Wi-Fi I can go from 866 down to the lower 400's and nothing is changing.  This seems like a rather extreme change but maybe it's normal.
I am using
2.4 auto
5 channel 36
WPA2-PSK [AES]
Enable 20/40 MHz Coexistence un- checked
Daisy Chain is off.
All 3 items below are checked
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enable MU-MIMO
Enable Fast Roaming
These setting seems to have made this connect to all of my devices the best and to the closest satellite.
Thank you in advance for your assistance.
  • FURRYe38's avatar
    Be sure to clear out all browser caches before entering the routers web page.
    Try a different browser to see if you can effect the change...
    Try a full on factory reset on the RBR and setup from scratch...
