vernonls
Apr 03, 2017Star
Orbi RBK50 dual systems on large campus with a wired ethernet backbone
Let us suppose that I have multiple static IPs, but I want my LAN to be seamless and my campus is too large to be covered by an Orbi and one or two satellites. Could I set up the first base/satellit...
peteytesting
Apr 03, 2017Hero
the simple answer is it wont work and if it even came close to working its would be a dogs breakfast interoperability wise
if you have ethernetnet run use propper wireless AP esp for that type of enviornment and client load you will find something like ubiquiti unifi aps will be cheaper and work better
