DK62's avatar
DK62
Orbi RBK50 Firewall Blocking ESET Antivirus Updates
I use ESET antivirus on my mac computer running OS Catalina. I've recently installed an Orbi mesh router in my home. Now my ESET gives an error when trying to update the virus signature modules. I've isolated the problem to the Netgear Firewall (when I connect my computer to the internet via a cellphone on a different network, the modules update fine). How can I fix the Netgear firewall to allow ESET to update modules?
  • FURRYe38's avatar
    Orbi doesn't block security progrems or update processes for app or other devices.
    • DK62's avatar
      DK62
      I just checked and my firmware is the latest version. I'm pretty sure my modem isn't the issue. However, I do use OpenDNS. I wonder if that would be the problem.
      • FURRYe38's avatar
        What happens if you use default DNS seen or detected by the RBR?
        Modem mfr and model is helpful. We are just checking for any router and wifi here is all. Helps us determine this as this can cause problems if present.
  • CrimpOn's avatar
    CrimpOn
    By chance is Bitdefender Armor activated on this Orbi?
    • DK62's avatar
      DK62
      No. I learned my lesson on that back in December and contacted Bitdefender's tech support to delete my account.
