Tommy3012's avatar
Tommy3012
Orbi RBK50 Firmware upgrade problem
got a handmedown rbk50 , firmware was 1.3.0.26  Both router and Sattelite.
Firmware upgrade sattelite is ok to 2.5.1.8 but router won't do anything . when i add the .img en press uplode the weel keeps on turning " please wait a moment " but nothing happens . update's 2.2.1.212 and 2.5.1.8 same issue . anybody know the solution ?
Thank You
kind regrads
T.
  • CrimpOn's avatar
    CrimpOn
    Jan 07, 2020
    (It just ruins the whole day when a problem does not get solved.  Damn.)
    My "absolute last resort" is to tftp the image. Netgear's routers are built with tftp (the most primitive file transfer program ever created).  Netgear publishes instructions for Windows here: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    I have uploaded firmware to an Orbi using tftp.  (It was either that or box it up and send it back to Amazon, and I had only one day left on vacation to get it working before I left the state to come home.)  Surprised hell out of me when it worked.
    My Google search seems to indicate that Mac's come with tftp, but I know almost nothing about Apple products.
    • Tommy3012's avatar
      Tommy3012
      i've tried 2.0.0.74 / 2.2.1.212 and 2.5.1.8 .  in chrome you can see the upload reaching 100 % then it says wait for Orbilogin.net to respond .
      the you get a connection error . when i log back in , nothing changed on firmware level .
      as i said , satelitte is ok with most recent firmware .  firmware upload is possible wireless ?
      • CrimpOn's avatar
        CrimpOn
        Have you tried another browser?
        I see no reason why a firmware update could not be done over WiFi, but I have never tried it.
        I am so old fashioned that I always access my Orbi by IP address, not the DNS name. Mine is the usual default, 192.168.1.1.
        (not that this should make any difference, but then it's supposed to be working and isn't)
        Did you do a "factory reset" on the Orbi before starting all this?
