Mike_EE
Jul 31, 2018Aspirant
ORBI RBK50 intranet speed?
Hi -
What is the maximum intranet (intra-home) speed from one RBK50 to another without an Ethernet backhaul? I would like to buy three of these, connect a master to my cable modem (and several...
Mike_EE
Thanks for the ongoing dialog.
I don't know what the ideal configuration is and am open to suggestion. I'm rather new to mesh(ing), as I have simply wired my homes with Ethernet in the past but have limited options in my new condo. This is why I'm looking for, without regard to the clients, the fastest room-to-room connection without wires. I've already tried a PL1200 system and it was much slower than the specs would suggest.
Again, thanks for the help!
Jul 31, 2018Guru - Experienced User
So you are trying to out fit this condo? How big is this place? SqFt and how many floors?
I have a Orbi system and use jusy the base and 1 satellite in a 5000sq ft home, two story. Router and satellite at at opposite ends of the home, 40 feet in between. I have great coverage and performance throughout the home.
- Mike_EEJul 31, 2018Aspirant
My condo has three floors and covers about 2,200 sq. ft. I have two entertainment systems and a home office, so three rooms that I would like have something that I can attach an Ethernet cable or two for the clients in each room. Perhaps this usecase only requires one RBK50, but what satellites would I need for maximum speed?
- FURRYe38Jul 31, 2018Guru - Experienced User
Ya for that size of home, you only need 1 Orbi system, not two. Orbi systems are based on size of your home and possible how many satellites you may need. You can add more satellites if needed. I would try the 1 base router and and just 1 satellite. Placement will be key. A good starting point is 30 feet minimum. Mines at 40 feet. I 1 satellite services two PCs and a DISH Joey thats LAN cable connected to a 5Ghz NG wireless bridge that connects to the satellite in the next room.
I set my freinds system up couple of months ago, just the base and 1 satellite, however his is wired back haul connected as single were the satellite is is poor for wireless back haul. Older thick walled home.
FURRYe38 -
Thanks for the feedback; I know understand that the RKB50 is a system and not just a single device - this wasn't immediately clear from the very pretty webpage. So it seems that I would need one RBK50 kit and one additional RBS50. Is this correct?
