creed0330's avatar
Oct 30, 2020
Orbi RBK50 IPOE?
My ISP protocol by default is IPOE, does anyone know how to config the orbi for IPOE operations?  I cant usee PPOE, I have tried, and as mentioned, IPOE is my protocol.  Any help would be much appreciated.
  • CrimpOn's avatar
    CrimpOn
    Would you mind sharing what the ISP is?
    This link seems to indicate that IPOE is commonly used by cable companies, which means you answer "No" to the question  "Do you have to log in?" and the connection is automatic.
    • creed0330's avatar
      creed0330
      Tutor
      ISP is centurylink, fiber, and no, no login creds required.
      • CrimpOn's avatar
        CrimpOn
        Lots of people have mentioned Centurylink fiber.  What happens when you go through the setup and just answer
        "Does your internet require a login" - No.
        Internet IP address
        "Get Dynamically from ISP"
  • FURRYe38's avatar
    Contact your ISP for help and information regarding IPOE.
    Hoffman_O wrote:
    I am facing problem in configuration,guys please help me
