pinayskee
Dec 10, 2017Aspirant
Orbi RBK50 losing connection everyday
My orbi loses connection everyday and I have to reboot it everyday to get internet. Devices that are on the wireless are the only one impacted. The devices that are hard wired to the sattelites and router are able to connect.
My orbi firmware is V2.0.0.74. I have disabled backhaul topology and enabled beamforming and MU-Mimo and still have the same problem. Any ideas on what else I can do?
- DarrenMSr. NETGEAR Moderator
You may want to try the 2.1 firmware you can manually download it and upload it to your orbi.
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/td-p/1447612
DarrenM
- pinayskeeAspirant
Thanks Darren. I have tried 2.1.1.12 and 2.1.1.16 but no luck. wifi connecttion drop every 2-3 days and now all my devices show as connected to router and some device are not showing as connected to any device even though they are. but that's the least of my problem. I am so close to jumping off the orbi ship as I'm tired of all these constant connection issue.
