Poh11's avatar
Poh11
Orbi RBK50 password recovery - security questions didn't work for me
Hello,
I need help to recover my admin password.  Tried the security questions for which I am quite certain that my answers were accurate -- first school I attended and my youngest brother's irst name.  Tried various permutations with capital and local case, but the message came back each time that info was wrong.
Not sure what I could do next. Any advice will be appreciated!
  • michaelkenward's avatar
    michaelkenward
    A factory reset will get you back to the default settings and password.
    There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
    If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
    If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
    • Poh11's avatar
      Poh11
      Thanks... will find some time to do a factory reset. Was hoping I won’t need to do that. But looks like that’s the option.
      Thanks Sensei!
        michaelkenward
        Did you ever set a new password? Have you tried the defaults?
