BANJI's avatar
BANJI
orbi rbk50 problems since firmware upgrade
1.  I am new to ORBI
2.  I purchased RBK50 Router PLUS Satelitte together in mid April 2020
3.  I connected my Orbi into my BTBroadband Router
4. Orbi was working lovely for one week
5. So impressed I then purchased RBS50Y Outoddr Satellite
6. It was working lovely for a further week
7. About 10 days ago the Orbi app  sent me a message to upgarde firmware
8. I did what the app said and pressed Yes
9. Since then the Orbi App shows No Sateliites on the Network Map and
10. the Orbi App show shows RBS50 and RBS50Y as separate Devices that are Unknown networks with Unknown Connection Trype and with very poor Internet Access signal
11. I have tried reset on each satelitte
12  I have tried contact Netgear Suppor via "chat" and phone.  That is a total waste of time
13.  I am a simple soul not used to tecchy wizardy or jargon so if someone can help I'll be most grateful / appreciative from a distance
14.  I want to be able to love my Orbi but at this moment I am very disappointed and I have learned NEVER to respond to firmward update message via the App
15   I beg for some insightful help
Thank You in anticipation
  • FURRYe38's avatar
    Do not use the Orbi app to update FW. Others have reported problems usng Orbi App. Preferred method is to use a wired PC and web browser and download FW files for the RBS and RBR. Updating the RBS first then the RBR lastly.
    Use NG support page and input the mode number of the RBR or RBK50 kit and RBS50Y to download the FW files for each:
    https://www.netgear.com/support/
    For modems with built in routers, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • BANJI's avatar
      BANJI
      Thank you very much
      I shall attempt this later today
      I think I’m right in saying that I do not use Orbi as a modem but only as a Router
      Kindest, Banji in London, UK
      • FURRYe38's avatar
        Orbi can't be used as a modem since it doesn't have a modem built in.
        Your BT modem is your modem however it already has a built in router. Why I included suggestions for configuring it with your Orbi.
        BANJI wrote:
        Thank you very much
