Browntownnj
Feb 24, 2021Aspirant
Orbi RBK50, RBS50 & RBS40V wifi calling issues
I’ve noticed that my rbs40v constantly drops the Alexa but not it’s wifi when connected to my rbK50 and rbs50. BUT I do have random issues with wifi calling dropping (not always disconnecting but def dropping for more than 10 seconds) if my device(s) switch from the rbK50 or rbs50 to the rbs40v. It’s as if it isn’t really augmenting the mesh but acting like a separate mesh within since it’s on the same network. Anyone else having either of these issues?
- vajimMaster
Any recent firmware updates?
- BrowntownnjAspirant
Im on the latest 2.7.2.104 but this was happening as well during the last fireware if not the last two. Basically when they dropped the 75% from transmit power, i started really nicticing this issue. The dropping of alexa has been going on fro the last 4 firmware updates and it seems to only fix itself for about a 2-3 week period after a reset, but im getting annoyed at having to reset my orbi every so often. Right now I can fix the disconnect from alexa with a quick power off but that still is ANNOYING.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
