Prestong87's avatar
Prestong87
Follower
Dec 09, 2018
Orbi rbk50 seems to be dead
My orbi router seems to be broken. The wan port when connected to my verizon modem seems to be dead as well. The light on the back of my verizon modem when there is an ethernet plugged in to a lan port lights up green and it does not do this when any of the lan ports are plugged into the wan port of my orbi. All other lan ports on the modem light up and I tried different ethernet cable to make sure that the ethernet cable wasn't defective. Also when attempting to reset the orbi with a paper clip, no lights even come on, on the top of the router like its supposed to as if it's not responsive but the power light on the back of the orbi is lit green to show there is power. When I hold the reset button the green power light changes to amber but after that nothing happens and the power light doesn't even come back on, I have to unplug it. I have held the reset button until it starts to blink amber and also for 1 minute and the same results occur. Anyone have any idea how to fix this?
  • FURRYe38's avatar
    What FW is currently loaded?
    Try swapping LAN cables between the modem and ORbi router.
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    If any of this fails, I recommend contacting NG support or return and replace the Orbi system for another. You may have a bad system.
  • Prestong87 wrote:
    ........ Also when attempting to reset the orbi with a paper clip, no lights even come on, on the top of the router like its supposed to as if it's not responsive........
    If no lights come up on the top of the router after rest then it looks like the unit is faulty.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Prestong87
    Please hardwired a computer to the Orbi Router and check Local Area Connection / Ethernet Status. Does it say "Network cable unplugged"? "Unidentified Network"? "Connected - No Internet Access"? Kindly check as well if it has an IP address. Try accessing the orbilogin page, go to Advanced TAB > Statistics page. If WAN port status is blank then we could say that the router WAN port is defective.
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi Prestong87
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      Blanca
      Community Team
