ender3424
Oct 23, 2019Aspirant
Orbi RBK50 Setup with Verizon Fios
Just bought a Orbi RBK50 - Router + one Satellite that I am going to setup in a 3000 sq foot house. House had Verizon Fios internet with a rented verizon router on 1st floor and the house has 4 floo...
CrimpOn
Oct 23, 2019Guru - Experienced User
ender3424 wrote:
3) Leave Verizon Router in line from the ONT, keep it as a router, connect Orbi to LAN port. This would be a double NAT config, which I am thinking may not be ideal? Could disable wifi on Verizon Router and then just connect wired/wifi devices to Orbi, but then everything would still be flowing through the original Network on the Verizon router.
There is one in wall ethernet drop run from the 1st floor closet with current verizon ONT + Router up to the 3rd floor. So I was thinking I could put Orbi router in 1st floor, use ethernet backhaul to connect to the satellite which is placed on the 3rd floor, or vice versa.
Very good description of the problem. Item #3 is incomplete. If the Verizon router stays, putting the Orbi in Access Point (AP) mode will eliminate the "double NAT".
Regarding the single (1) in wall ethernet, which for discussion we assume will handle gigabit speed. Ordinarily, I recommend placing the Orbi router where the most traffic sensitive devices can be connected to it, preferably using ethernet. However, with only a single ethernet cable, putting the router on the 3rd floor would "use up" that single cable, leaving the satellite with only 5G WiFi for backhaul. My choice would be: router on floor 1, satellite on floor 3.
As Retired_Member says, WiFi placement is tricky. Ordinarily, "center of the space" is best, unless of course all the devices are on one side with nothing on the other side. Metal, stone, and brick degrade WiFi signals more than air and drywall. So, next to an AC duct is a non-starter. WiFi radios do not perform as well when they are stacked vertically. Typical omni-directional antennas have a "torroid" radiation pattern, with significant nulls directly above and below. After experimenting, you may find that the satellite needs to be "offset" horizontally from the router.
Good luck.
- ender3424Oct 24, 2019Aspirant
Oh so for #3 if the Orbi is put in AP mode, then it would not perform DHCP correct, the verizon router would do that? In that case I should still disable the wireless boardcast from the Verizon Router I assume?
I am thinking more that router on 1 and Sat on 3 with etherent back haul sounds like the way to go, reguarding this, if they are connected via ethernet backhaul, does the Router have a more powerfu Wifi broadcast than the Satellite per say? Or with etherent backhaul are they somewhat similar? Only thing is that most of the devices will be on the 2nd and 3rd, 4th floors, so most would be connecting to the satellite.
If I was to use wireless backhaul, the Router would go on the 3rd floor and probably the Satellite on the 2nd floor, it would be going through drywall, and it sounds like I should off set them a bit so they could be about 25 feet apart I would say but it would be through this 3rd floor ceilng of course.
Thanks I will try different locations
- CrimpOnOct 24, 2019Guru - Experienced User
ender3424 wrote:Oh so for #3 if the Orbi is put in AP mode, then it would not perform DHCP correct, the verizon router would do that? In that case I should still disable the wireless boardcast from the Verizon Router I assume? Yes. When the Orbi is in AP mode, the Verizon router assigns IP addresses to all devices using DHCP (including the Orbi units). And, the whole purpose of purchasing Orbi is to use Orbi WiFi, so the Verizon WiFi should be turned off.
I am thinking more that router on 1 and Sat on 3 with etherent back haul sounds like the way to go, reguarding this, if they are connected via ethernet backhaul, does the Router have a more powerfu Wifi broadcast than the Satellite per say? Or with etherent backhaul are they somewhat similar? Only thing is that most of the devices will be on the 2nd and 3rd, 4th floors, so most would be connecting to the satellite.The router and satellite radios are identical. Both the same strength. With ethernet backhaul, it doesn't matter that most of the devices are connected to the satellite.
If I was to use wireless backhaul, the Router would go on the 3rd floor and probably the Satellite on the 2nd floor, it would be going through drywall, and it sounds like I should off set them a bit so they could be about 25 feet apart I would say but it would be through this 3rd floor ceilng of course. (typo? 2nd floor ceiling = 3rd floor "floor")
- FURRYe38Oct 25, 2019Guru - Experienced User
25 feet maybe too close, see if you can get them out to 30 feet.
