toystwo
Jun 13, 2018Aspirant
Orbi RBK50 to Mobile Hotspot
I'm trying to connect an RBK50 to an ATT Mobile Hotspot as the internet source. I purchased an IOGear GWU627 Adapter/bridge in order to get the internet connection from...
Jun 13, 2018Guru - Experienced User
Something to ask the Mfr of the adapter/bridge to see if this model router is supported. The Orbi router relies on a Cable or DSL or FIOS/ONT type of connection using RJ45 connector on the WAN port. DHCP/Static or PPPoE kind of protocols are used on the Orbi router.
Possible that this adapter doesn't support this...
toystwo
Jun 14, 2018Aspirant
I don't know if the 627 has been used successfully with an Orbi. As far as I can tell none of the adapters specifically claim compatibility for this type of use (although some are used successfully). IOGear basically says may or may not work with routers in Amazon Q&A. Do you know of a model that works with Orbi? The 627 is currently set to DHCP.
- FURRYe38Jun 14, 2018Guru - Experienced User
Sorry I don't have any experience with this kinds of adapters. I don't know if NG even tests with them.
