Grahamerin's avatar
Grahamerin
Initiate
Apr 29, 2020
Orbi RBK50 to TPG FTTC connection
Hi,
We purchased an Orbi RBK50 and had an issue connecting to the internet via our TPG FTTC modem. We followed the advice in the discussion group and logged into the Orbi from an internet browsers rather than through the app. We went to advanced setup and enabled and changed the VLAN ID to 2 via VLAN/bridge setting “by bridge group” and chose port 1. This made the internet connection work but now one of the Ethernet ports on the back of the Orbi will not work. Any suggestions as we would like to plug in 3 devices via the ports?
Thanks
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
    This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Grahamerin wrote:
    Hi,
    Thanks
    • Grahamerin's avatar
      Grahamerin
      Initiate
      FURRYe38 Retired_Member
      Thanks for your replies.
      The NBN modem is a NetCommWireless FTTC Network Connection Device model NDD-0300
      Will configuring the modem for transparent bridge or modem only mode fix the Ethernet ports on the NG router?
      Thanks
      • Anonymous's avatar
        Anonymous
        Thanks
        Thank you:smileyhappy:
