Cheeser64
Oct 07, 2018Aspirant
Orbi RBK50...want try Ethernet backhaul again - suggested config
I want to try Ethernet backhaul again after giving up on it this summer...tried multiple configs without any luck.
I am using an Asus AC86R router, with the Orbi main unit in AP mode, and the s...
Cheeser64
I went ahead and tried the following:
Both Orbis assigned fixed IP addresses.
Asus router lan port to Netgear unmanaged switch
Orbi Master setup in AP mode and "daisy chain" setting disabled.
Orbi Master internet port to Netgear switch
Orbi Satellite lan port to Netgear switch
This didnt work at first, so I tried connecting satellite directly to master and it worked. I then reverted to the setup above and it worked.
The only issue I have noticed so far is the Satellite Orib web page shows 4 connected devices, but on the Master Orbi web page, its says those same 4 devices are connected to the Master.
- ekhalilOct 07, 2018Master
When you have a wired backhaul then wired devices connected to the Satellite will appear as connected to the Router under "Attached Devices".
I guess this is because everything will be connected to the same "switch" and the system will not be able to differenciate between those devices connected to the Router (wired) and those that are connected (wired) to the Sattelites
- Cheeser64Oct 07, 2018Aspirant
The 4 devices connected to the satellite are wireless. I would have assumed the satellite would have passed that info to the main unit in order for the main unit to properly illustrate that data on its "attached devices" page.
- FURRYe38Oct 07, 2018Guru - Experienced User
When the satellites is wired to the router, devices, even though connected to the satellites will appear as wired to the router.
