Cheeser64
Oct 07, 2018Aspirant
Orbi RBK50...want try Ethernet backhaul again - suggested config
I want to try Ethernet backhaul again after giving up on it this summer...tried multiple configs without any luck.
I am using an Asus AC86R router, with the Orbi main unit in AP mode, and the s...
Oct 07, 2018Guru - Experienced User
The main process is to get the satellite to connect wirelessly first, then connect the satellite with LAN to the Orbi router. Wait 5 minutes for the top to turn on BLUE. Once this happens, reserve an IP address for the satellite ON the router. Then you should be good to go.
Glad you got it working though.
Enjoy.
